Thought I should litter this thread to show how I mounted my Baja SS's
tucker74 said:Man - you guys are spending way to much money here ... '94 Celica seats from the bone yard ($60). Adjustable lumbar, height, etc. - almost a bolt in swap.
Tucker
TLCSKULLS said:Here's a link to a few pics I took tonight. The PO welded in the seats he used So I can to cut up the stock brackets a little. I used 5/16 flat iron to put in some new cross baces and then bolted the seats to those. The seat came w/ the sliders already on. It's kind of crude, but I did'n have a welder then, only a drill press and chop saw.
skulls.shutterfly.com
wantatlc said:nice. now I see what you did, pretty easy garage fab to make them work.
if you could, could you post a few showing the full seats installed so I can get a feel for what they look like in the rig. thanks
My question too.How much "almost" was there to the bolt in?
My question too.
Mind including a detail shot of the seat mounts??? Some of us are working at fixing aching behinds with new seats!!! (Sweet rig BTW!)
Cheers!
Seats use the factory brackets - they are out of a '94 Celica and the mounts were 1" narrower than the stock on each side. I just bolted 2" flat stock to the factory mounts and mounted these directly to that ... easy breazy.
Tucker
