Love this one!! You need a build thread.I am running Freedom Retrofit LED headlights, they are projectors in Depo housing. They have been great so far.
It would be terrible because of the fluted lenses. Depos are a glass lenses.I tried to find those housings and LEDs but came up empty. Do you remember where you got them?
Are the housings plastic? Would upgraded lighting in the factory glass housing be better due to the longevity of glass?
They were an option with them a while back. I run the Baja spot in my high beam and it was a great combo.It looks like you have amber lights on the low beam. The freedoms I found in a google search don’t have that, did you modify them or get a custom set?
Are there LEDs out currently that work with the factory reflector or is halogen the better option?
Do you have a link to the HID kit you mention?Factory Hologens and HIDs will function better as the housings were designed for omni-directional light sources. LEDs are not omni-directional but some companies have added additional LEDs along the X- and Y- to help simulate this however it usually results in scattered light patterns and dark spots.
Some option include swapping the H11 bulb with an H9, the H9 is a hotter burning bulb that is most commonly used in high beams but also burns out more quickly.
I recommend an HID kit as they are pretty easy to install, omni-directional, can leverage it's own relay, and the 35w version usually has about 2.5x the light output.
Can't find H9011 anywhere, is this a typo?If you want a cheap quick upgrade while you shop for a permanent upgrade, go out and find H9011 halogen bulbs. You will have to modify them slightly to fit the harness and housing but it’s an instant 50% improvement in output. IIRC, Rockauto has Wagner bulbs (Philips bulb in Wagner box) for about $11 ea. Takes about 5 minutes a side with a sharp blade, clippers or cuticle clippers and you are done. Keep the old rubber o-rings from the original bulbs for a better seal.
It's just 9011.Can't find H9011 anywhere, is this a typo?
Thanks for the clarification Jon.It's just 9011.
Stock bulbs were 9006/9005 for low/high.
9012/9011 are the HID bulbs that require tab trimming to fit the OEM housings.
I run 9011 in all 4 positions.
Sorry, 9012/9011 are HIR, not HID.Thanks for the clarification Jon.
