- Thread starter
- #21
No I have not. But immediately after shutting it off I've opened the gas cap and there has been no noticeable suction or pressure.Tried running it with the fuel cap off?
So today after I drove it to get it up to temp, I noticed that my accelerator pump wasn't squirting a strong stream of fuel out. Every other pump it didn't seem to pump fuel at all. I'll investigate that further.So, the fuel in the floatbowl disappears after a hot shut down? That is unacceptable. What if, just for fun, you re-filled your floatbowl before a hot restart?
I vaguely recall a thread mentioning a siphon type carb phenomenon, but paid little attention as i didn't have that problem
I will give that a try today.Still sounds like a fuel problem but if you tip fuel in the top and that still doesn't fire then maybe there's more going on.
You said your spark was orange which isn't a good sign. Your coil+ is wired through the ignition switch to +v.
Try bypassing this by running a length of wire from the battery directly to the coil. If you have enough resistance in the ignition switch harness then the coil voltage can be too low to be reliable.
I have two coils, both brand new and both with similar results. That was my first part to test/replace as. My coils are not hot to the touch after running and pass all the resistance measurements, but I went ahead and bought a 2nd one to test anyways with identical results.I’d put a new coil on it. You should have a spare one anyways.
My father in laws 1950 something tbird wouldn’t start after running two weeks ago. The coil was super hot to the touch. Replaced the coil and bam, no more problem. You can check the resistance cold and hot and see if there is a big difference.
It went rump rump a couple times, but then just cranked without any indication of firing. Basically the same as when I poured gas down the carb or give it several pumps of the accelerator pedal. It rumps a couple times, but won't fire/catch/start.Did it diesel on the start spray at all, or absolutely nothing?
You said your valves were freshly adjusted.. sure they were right?
You didn't retorque the head after adjusting the valves for example?
Maybe you could try a different approach?It went rump rump a couple times, but then just cranked without any indication of firing. Basically the same as when I poured gas down the carb or give it several pumps of the accelerator pedal. It rumps a couple times, but won't fire/catch/start.
My valves were ground and lapped by myself about 200 miles ago. My compression is ok, not great, but ok.
New head gasket and retorqued all head bolts when reassembling. The hard starting issue was unchanged before and after the valve job. The only difference is a large increase in power and torque.
Now that you mention it, I did verify all valves were adjusted to FSM spec yesterday as well.
I'll give it a try. I get a good "click" when I turn the key to the ON position, but maybe the heat is weakening my ground connection.Do you have a good ground for the idle control solenoid on your carb, run a hard wire from the -ve terminal to the carb housing to see of this changes anything
When you say bump starting I assume you mean rolling it down a hill or similar and then popping the clutch in gear? If so, that makes sense because I have indeed bump started it before when the idle circuit was clogged and it died on the road once. Started right away once I popped the clutch.Sounds like the ignition circuit is just on the edge of working for whatever reason.
While you're cranking, the battery voltage is lower and making it not work while hot.
Once running its at full voltage.
I bet you could bump start it with no problem.
Measure the coil voltage while cranking - its probably too low for the electronic pickup.
You have two batteries - rig up one of them for the coil and the other for cranking. Both negatives together but separate the positives
You haven't got enough voltage to make a good spark, and it's probably caused by several things, but fixing one of them might solve your problem.When you say bump starting I assume you mean rolling it down a hill or similar and then popping the clutch in gear? If so, that makes sense because I have indeed bump started it before when the idle circuit was clogged and it died on the road once. Started right away once I popped the clutch.
