I’m still on 4.11 gears with 33s. Most of the time I cruise at 80 mph at 2850 rpm in 5th gear. With 3.70s I’d be at 2570 rpm at the same speed. That’s roughly a 280 rpm difference. Not worth the swap for me, I would rather keep the small off road gearing edge than chase marginal highway rpm improvement.Are you still running the original gears? I'm thinking of swapping in 3.70 gears.
High revving is no issue with an LS. Not the case with the 2Fs.I’m still on 4.11 gears with 33s. Most of the time I cruise at 80 mph at 2850 rpm in 5th gear. With 3.70s I’d be at 2570 rpm at the same speed. That’s roughly a 280 rpm difference. Not worth the swap for me, I would rather keep the small off road gearing edge than chase marginal highway rpm improvement.
@SipLife @cruisermatt I'm having an OME 2" lift installed and hope to run 33's as well on my otherwise stock '70. I see your commentThe 2.5” lift OME goodies came in today. Installed the new springs and bushings and torqued and greased everything up. The new kit didn’t come with new hardware for the shocks so will get those in later.
View attachment 2727582View attachment 2727579View attachment 2727580View attachment 2727581View attachment 2727583View attachment 2727585
Also moved my rear axle to the forwards hole because OME tends to move the rear axle too far forwards in the wheel well and it looks funky. Thanks for the heads up @cruisermatt
It’s an OME specific issue where the rear axle is slightly forward instead of centered in the wheel well opening. Just tell your mechanic to drill a new hole 1” forward of the center hole in your spring perch.@SipLife @cruisermatt I'm having an OME 2" lift installed and hope to run 33's as well on my otherwise stock '70. I see your comment
"Also moved my rear axle to the forwards hole because OME tends to move the rear axle too far forwards in the wheel well and it looks funky. Thanks for the heads up @cruisermatt"
Is this something specific to 40's I need to tell my mechanic to do? If so, what would the exact directive be? Thanks!
And a corresponding new hole in the u-bolt plateIt’s an OME specific issue where the rear axle is slightly forward instead of centered in the wheel well opening. Just tell your mechanic to drill a new hole 1” forward of the center hole in your spring perch.
@brooklyn check out this 1” adjustment on the springs- it may remedy your situation.And a corresponding new hole in the u-bolt plate
Nice setup. This is the square to round Spectre adapter I used.I really like that. I’m working on something almost like it myself. Where did you get that square to round adapter? I’m still trying to figure a way to pull from that side vent too. Here’s how mine is coming. It’s a generic K&N kit.
Thanks man. Look forward to seeing y’all in 21 days!Looking great! Excellent work.
It may have helped if you didn’t decide to swap your entire drivetrain and rear suspension 3 months prior this year lol. I will say preparation is a lot easier this year with the cruiser as the dailyI'm stressin like every year lol. Too much to get done, never enough time.
Pretty sure that he’s been working on the swap for almost a year.It may have helped if you didn’t decide to swap your entire drivetrain and rear suspension 3 months prior this year lol. I will say preparation is a lot easier this year with the cruiser as the daily
I did see it at Cruise Moab it’s one of the cleanest well executed one off swaps I have seen!!
Really nice work DJ !!
Looking forward to see y’all at SAS
That was Feb of last year, time for some mountain air . Will be looking for it at SAS, hopefully KOA patrol doesn't find it first.
