WarDamnEagle
I’ve posted these before….
Now that is funny... missed this forum..So is getting on a very friendly forum and insulting other people’s efforts. Your right finger obviously works, use it to scroll past things.
What is the object? Wagon? Wheelbarrow?
What? That's it? No flavor?? We need to know all the issues you had. A small fire broke out, forgot to bleed them and drove anyway, lacerated a finger requiring stitches c'mon spill it!
Well I left out the part where I was holding the clutch MC so it wouldn’t fall and kink the line. I had to set down my 12 so I could free hand the last few threads.What? That's it? No flavor?? We need to know all the issues you had. A small fire broke out, forgot to bleed them and drove anyway, lacerated a finger requiring stitches c'mon spill it!
He is on his own!But did you help the armadillo with his loose hub bolts?
Smoking cats are a scourge!!! Mine has syphillis too, and a neck tattoo! Thank god you made it thru. Plus, always have 2-3 12mm wrenches nearbyWell I left out the part where I was holding the clutch MC so it wouldn’t fall and kink the line. I had to set down my 12 so I could free hand the last few threads.
Before I knew what was happening. an armadillo scurried up and made off with my 12mm combo!
I was going to call out to my cat when I saw I was about to have another issue, very soon!
I have trained my cat to dispense high octane aviation fuel into the Pig before my outings. He is very good this, like really good. The only problem is he sometimes forgets to put the gas cap back on.
I had just heard the clank of the cat racking the fuel nozzle when the armadillo made his move. Just as I was about to yell out, my cat sparked his Zippo and was about to light up a smoke. I have told him many times about the health risks of smoking. He knows it is a bad habit, but it helped him quit the catnip.
He basically traded one vice for another…
I saw the flame travel back from the Zippo to the fuel inlet on the Pig. I knew once the positive pressure in the tank stopped venting we were going out in a mushroom cloud.
I reached out with my foot, rolled my fire extinguisher back towards me, flipped it up, pulled the pin with my teeth, and pulled the trigger.
The torch venting from the tank went out and I dropped the fire extinguisher. I pointed in the direction of the fleeing armadillo and bellowed, “Cat! 12mm!”
Like a bullet, my cat easily overtook the armadillo and wrestled my 12 from his claws.
He brought my wrench back to me and I finished the job.
I forgot about that part.
Smoking cats?Smoking cats are a scourge!!! Mine has syphillis too, and a neck tattoo! Thank god you made it thru. Plus, always have 2-3 12mm wrenches nearby
OK it’s official…I will take Ron’s optimism and apply it. Residual flakes only and no more issues expected going forward. Plus I need to focus my energy on replacing my rear window gear before the PP!I used the Renew Company for my M37 tank and never had a flaking problem? Hopefully it was some left over residue and it will clear up. I always had high opinions of the company.
