Test fit 3FE downpipes. @HemiAlex posted about these as replacements with a 3FE exhaust. I decided to purchase two rear pipes to see how they would fit. Not well and I kind of expected this. Using the rear pipe in the front will not work due to mounting interference with the rear pipe. But hey, this was a test and we'll be having an exhaust fabbed anyway. When we have an exhaust built it will eliminate having one of the pipes routed under the frame. This was a reason I wanted to see if using two of these aftermarket pipes would work. Our exhaust guy is good and he'll be able to put something together to retain the O2 sensor positions and route the pipes within the frame.
View attachment 3322046View attachment 3322047View attachment 3322048
That’s pretty good. Some cutting and welding and you’ve got a nice solution that’s like 75% out of the box.
