Hi, I just got this part and my mechanic told me it was NOT a direct bolt on, can anyone give me a little advice how you installed it?
thanks
Vincent
thanks
Vincent
He’s wrong. The old one unbolts and the new one bolts right in. Unless you got a mispackaged unit that is not in fact the part number you’re in need of. It’s two bolts. Super easy. You can do it yourself in five minutes.Hi, I just got this part and my mechanic told me it was NOT a direct bolt on, can anyone give me a little advice how you installed it?
thanks
Vincent
part#OMESD24
the guy is my long time old school mechanic. He fixes my old jaguar with a lot more complicated problems and I went to his shop this morning and he showed me. so I have no problem to trust him on that, if it was just bolt on. he will be more than capable doing that . I expected to be a direly bolt on also.He’s wrong. The old one unbolts and the new one bolts right in. Unless you got a mispackaged unit that is not in fact the part number you’re in need of. It’s two bolts. Super easy. You can do it yourself in five minutes.
Thanks. That's also weird mine didn't have any branding lettering on it.Here is mine installed. You may have the wrong unit or maybe you’re missing hardware? This is an 87 fj60 fwiw. Should be the same as the 62.View attachment 2918410View attachment 2918423
Or you could call cruiseroutfitters and they’ll tell you what is what.
I just installed omesd23 on my AUS HJ47. but it didnt fit as well.. does the pin sit concentric with the rubber bushing? Mine is off axis and I can't get the pin to fully seat inside the bracket holes.
