- Location
- United States
FJ60 Parts Haul
All these parts came off a 82 Fj60. Hopefully someone can use some of these parts. Most of it I can fit in plat rate boxes which will be added to the price some of the bigger items I'll need to figure shipping.
-Horns $25
-Throttle Linkage $30 sold
-Coolant reservoir bracket $20
-Fuel tank evap canister $25
-Fuel Filler neck $45
-Rear Side vents $40
-Hood Latch cable $35
-Headlight bucket $25
-Rear washer bottle bag and motor. $40
-Trans hump cover $30
-Power steering box and linkage heat shield $20
-Several hard vacuum lines $30
- Battery tray bracket $30
-Dash Bezel various switches $40 (Crack that could Tibe repaired)
-Rear wiper switch $15
-Rear Defrost Switch $15 sold
-Parking brake light switch $15
-2f oil pan $75
-Exhaust downpipe with EGR pipe $150
-right side wide defrost hose $15
-Various Exhaust heat shields $25 each
-Fan and Clutch $40
-Timing cover $35
-Sway bar mount $15
-Brown door handle $30
-Clutch fork $20 sold
-Belt Pulley $25 sold
-parking brake cable $40
-smog parts not complete $40
-brake booster and master check valve nipple broke. $45
Engine hoist hooks $35
Starter $45
Vents $40 sold
-Horns $25
-2f oil pan $75
-Fan and Clutch $40
-Timing cover $35
-Sway bar mount $15
Starter $45
Vents $40 sold
