- Thread starter
- #21
yep dizzy is fitted in right at TDC cylinder 1 at compression stroke.
how many degree's off is the timing, what does the FSM say is correct? if you can't find a correct timing setting within @ 6 degree's, you are probably off a tooth timing gear, if everything else is correct.
