What's your record for change? I found just short of $4.00 when I gutted mine.
I'm both anxious and apprehensive for the day to pull my seats. I don't think the PO (original owner) ever pulled them...so, it's near 30 years of STUFF on that carpet mixed with years of water seepage. It's mostly why I'm going to replace the carpet and add new sound dampening film (and replace the seats).
Mine was full of peso’s in nearly every crack possible.... and my cynical mind then started to wonder how many times it had been back and forth across the border and for what purpose.... (it also doesn’t help when the Carfax shows it was stolen and recovered at one point in its illustrious history)What's your record for change? I found just short of $4.00 when I gutted mine.
$21.xx for meWhat's your record for change? I found just short of $4.00 when I gutted mine.
Nice!! DId you do it yourself? If not what did it cost you?
It may just be the angle of this photo, but it appears the hose clamp at the block may not be on the port completely. I remember when I've done all of mine in the past; they usually sit closer to the block of the engine. Just my .02 cents.Did 2 things this weekend...sourced the hose and clamps and made my own PHH kit to install, and put these new wheels and 35s!!View attachment 3283610
Do bobby pins count? I found so many that I ended up using a magnetic tool holder strip to pick/pull them up from everywhere. STILL finding randoms after driving or wheeling it. There had to be at least 1000. I wish I would have kept them all for pics!!!What's your record for change? I found just short of $4.00 when I gutted mine.
From this photo it looks like there is a ton of room that would make this job super easy to doIt may just be the angle of this photo, but it appears the hose clamp at the block may not be on the port completely. I remember when I've done all of mine in the past; they usually sit closer to the block of the engine. Just my .02 cents.
I just updated the post to try and provide a reference from the most recent one I did. You really want to make sure that the clamp is on the other side of the rib on the coolant port. Otherwise, you're at risk of having a catastrophic failure.
It was a passing reference to something interesting with land cruiser overlap. Sue meWhy are you even discussing this here? “What did you do with your 80 this weekend”. Try to read the room man.
Yeah, plenty of threads to post LC stuff in around here. Pick an appropriate one.It was a passing reference to something interesting with land cruiser overlap. Sue me
Thanks for pointing that out, I really appreciate it! I'll give it a closer look and adjust as needed.It may just be the angle of this photo, but it appears the hose clamp at the block may not be on the port completely. I remember when I've done all of mine in the past; they usually sit closer to the block of the engine. Just my .02 cents.
Yep did it in my driveway over a couple days (mainly because I had to Easter egg hunt with the kiddos) but it took roughly 3 hours I would guess.Nice!! DId you do it yourself? If not what did it cost you?
Why would I do that when I can watch you throw a fit about it? If someone wants to yank my comment from the thread, they will, and that's fine. Until then, what's done is done.Yeah, plenty of threads to post LC stuff in around here. Pick an appropriate one.
Are those the carhardt seat covers? How do they fit? They look pretty snug, which is what I'm looking for.Picked up a 94 motor from the machine shop and an extra head!
Nice! Always enjoy getting extra head.Picked up a 94 motor from the machine shop and an extra head!
Marathon covers. I love them but my wife says they are to rough. They are a rough canvas for sure.Are those the carhardt seat covers? How do they fit? They look pretty snug, which is what I'm looking for.
