DoubleNickels
Nice. I recognize that "stout table" and shop background. Nice to have well-equipped, capable amigos.
How similar are we talking? My troopy is already an OEM monstrosity at this point. The entire roof was rotted thru and crappily repaired before I got it… need a new oneI’ve got a pop top eurovan I’m getting ready to part out…if you are feeling extra DIY that poptop is very similar dimentions to a troopy
Tempting...I'll have to take a closer look at a eurovan. Would it sit interior to the gutter and seal to the roof or does it seal at the gutter?
I don't like the looks of the Alu-cab and don't want to lose any interior head-room. We sit in the back pretty often and any lower roof than stock would not be comfortable as you'd hit your head or have to duck the entire time. So closed, I'd want it at the stock height on the inside.
you cant loosen the center clamp and rotate it?Other gripe is the alignment of the outlet to the crossover pipe is off by a couple degrees. I was able to get the hose to seal, but it needs rotated up about 2-deg.
Not sure, but I think I know why the housing is misaligned and maybe why I'm not getting full boost.
Note the alignment (or misalignment that it) of the actuator rod.
I think that is binding up the wastegate
I removed the circlip and the wastegate moved freely. I took one of the actuator mounting bolts off (lower not shown) and rotated the actuator out a bit and drove to work like that. Got maybe one more psi out of it (11.9) Also turned the fuel screw one more quarter of a turn.
I think I'll swap my old actuator on next. Note the bend in its arm.
I still think I should be getting at least the same boost out of this turbos as the old turbo was producing with the same fuel pump settings.
The supplier states that I just need a 'tune'. I think I need a new actuator arm that's more aligned with the wastegate.
Ran the old actuator with the same results. So far I've turned the fuel screw in about one full turn in 1/4 turn increments. Max EGTs are around 1350-1400 F, not too smokey yet (IMO). Gonna quit adding fuel and see if I can adjust the actuator for more boost.
Fiddled with the new actuator bracket and swapped it back on. I rigged up my bike pump to the actuator and it's opening around 10 psi (gauge resolution on the bike pump isn't that good, first mark on the gauge is 20 psi) I shortened the actuator rod two turns, max boost went up to 12.5, turned it one more turn this a.m. and its up to 13+ psi.
Noticed my water temp gauge isn't moving at all...need to figure out what's up with that now too.
Hmm, somethings not right. Did you try the old visgrip block the wastegate hose? That would take the actuator out of the equation.
Do you have a link to which turbo you ordered? You said the turbo is bigger which is kind of the opposite that people do to 13bt/14bts.
Yep sounds like maybe just some wastegate adjustment. What boost are you wanting to max at?Crimped the wastegate hose shut with some vise-grips this a.m. Didn't get it up on the highway, but on the short drive, it hit 17 psi.
Thanks for the advice. I'll continue adding pre-load to the spring, turned the rod in two more turns.
