What Did You Do with Your 80 This Weekend? (71 Viewers)
quick blinker housing polish
Steering wheel looks great! How good is the supplied thread that you use to sew it on?
Thanks. The thread seems fine. I pulled on it pretty hard a few times tightening up some of the spots in the tight corners and it never broke on me.
After 5 years and only 7500 miles on Toyota sensors, I was getting the dreaded 28 code and my engine was running rough as hell! I ordered a set of new sensors and got them in the mail today. Due to the fact that I have such low miles on the previous sensors I’m going to soak them for a few days in brake cleaner and see if it will prolong them for a little while before I put the new ones in.
We’ll see what happens:meh:
Got stuck on a minimum maintenance road with few options to winch from. Got out though without having to touch a shovel. So that's a win
Backing out is where I screwed myself. I'm thinking I should've done that in 2wd, not locked.
Mine’s been my daily, since I’m in the market for a new work truck.
Not bad for some early Spring glamour shots. At least it’s not on pavement!
You're going to love the WKOR's...excellent fit & finish and easy to install. I replaced my cats recently and checked the threads in the frame for the mount behind them (which were clean fortunately on mine)....that would be the only bastard issue if the threads need to be chased. The bolt that everyone cranks about on the brake line really isn't that big of a pain if you take your time.
You're rig is stupid clean! (That's a compliment btw) Looks great!
Went out with some new friends and ran from Camp Sherman near Black Butte to Madras, OR…went from snow to the high desert with a family members dog as my copilot 👍
One of the best compliments I've received went something like this:
"You know...you just look at a person and then their rig and say, Yeah...that looks like you. Dusty, that's you and your Cruiser...Like you, that thing just GOES."
A few more…
Also set up the VeePeak Bluetooth OBDII device ($30) and tethered it to my old iPhone and downloaded OBD Fusion ($9.99). Set it up next to my A-pillar 👍
The thing I like about the reader is that it has a MUCH SMALLER footprint than the other one I used with the Samsung Tab-A (10 inch).
Overall, very happy.
ALSO picked up a 4k trail cam and will post videos on the next run.
Much appreciated! Rolled by you 2 weekends ago to Good Evening Ranch in WVA to get a little mud on her and flex the suspension a bit just to prove it's not a poser....;) All cleaned up now with a fresh power wash....
