It has bottom end bearing issues that need to be fixed if it has not.1HDT
The simplest of all you propose
I am at the research stage so I am considering most options but trying to stay Toyota. I am also looking into H151f transmission. Not sure how much modifications is needed, I am also trying to figure out if my h55 can handle this kind of power.thxFTE - with new pump, +70 injectors, unichip and Gturbo/UFI it’ll easily put out 400hp at the wheels and 740 ft-lbs+. It’s simple compared to new engines especially when stripped down to the bare essentials. FT is the next down but won’t be able to come close on terms of power. Don’t even consider a T.
But 6BT is probably worth thinking about
I have all kinds of reinforcement on the chassis including airbag etc. if you noticed my chassis is also extended to accommodate the camper box. ThxI'm amazed that chassis handles 10,000 lbs. You must be a very careful driver to avoid suspension and axle problems. The low engine power might just be your saving grace here.
I'm a fan of Cummins engines and while a 5.9 Cummins would handle the job in style I feel it would be a poor fit as your vehicle does not have the cooling capacity and the rest of the drivetrain would become a fuse for the power.
It is fairly well accepted you can squeeze a little more power out of a 1HZ than 1HDT, but not by much. And at the those power levels the inherent weakness and cooling issues of the fragile and complex 1HZ head will show themselves. Overheating, Cracked heads and cracked pistons are the rule at high power levels and this will be compounded by a heavy load - everything needs a much higher build standard with heavy loads, look at the hp/kg of a semi engine. 1HZ are only reliable NA, and even then a stock 1HD-FTE will have more miles in it due to it always having spotless oil (unlike the instant tar the 1HZ generates). FTE pump and injectors last at least twice the distance as 1HZ too - I’d wager a 1HZ pump will fail before the electronics in an FTE play up. The only advantage a 1HZ has is coping with bad fuel but a decent filter setup goes a fair way to helpingSome folks may think I am full of bs but I met an engine builder recently with over 6000 builds under his belt. He reckons he can get more from a hz with a custom turned up pump and turbo from a hz than what is possible from a hd, probably hd-t. He prefers the hz over the hd. MS engine reconditioners on facebook in Melbourne, Oz. Really nice fella, loves sharing his knowledge, shall die with a spanner in his hand.
On the other hand, there are some super duper injectors for the hd which can deliver 400hp or something, as wedgie pointed out. Aussiehjcruza on here loves his hd. Maybe he shall chime in. But , personally I reckon electronic injection would always be more finicky upon fuel. Let alone ecu's and stuff..
From what I know of the difference of the hz it is more suited for the locations you travel. It is well known a hz would get a million kms, but have not heard of the hd getting a million kms.?
My two bob for toyota engines for you..lots would say cummins 6bt, it is pretty legendary.
But also the worst option. You can’t fix the BEB issue - only keep replacing them. It’s an inherent design floor from the piston pulses. And it’s most gutless stock with the least power potential1HDT
H15* series will handle the power better.I am at the research stage so I am considering most options but trying to stay Toyota. I am also looking into H151f transmission. Not sure how much modifications is needed, I am also trying to figure out if my h55 can handle this kind of power.thx
Staying Toyota diesel 1VD-FTV has the most power potential but FTE will be the most reliable
yeah, nothing like mud!All this is way outside my wheelhouse, I am always impressed by the free exchange of information on this forum.
Just a side note on the 12ht, last I looked at hj61s on carsales , there actually was quite a few good looking 12ht's on the market., well, at least a dozen. All had a very healthy price for their age and all had at least over 500k kms, not many engines stand out like that. The sellers all knew what they had.
Two of them and you won't have to talk no more!
several years! patient fellow , ahh money . My finances simply force me to live in the 2h realm, being slow suits me fine, at least I can pull some weight at least. Your coin is virtually same here.I've been looking for a 1HDFT for several years here in NZ, basically none have turned up. Current rates ($NZD)
1HZ - $2-3K. Most have insanely high km.
1HDT - From about $4.5k. Most look rooted.
1HDFT - North of $6k
1HDFTE - North of $10k.
12HT - Haven't seen one out of a truck, seen a few 60s with them, anywhere from 12K depending on how much rust.
Add about 20% if being sold by a wrecker.
That's the one!!!
