For Sale LHD HZJ70/73/75 AC kits for sale (1 Viewer)
joekatana
GOLD Star
Texas
I just got back from Europe and have a container on the way with more goodies and finally was able to get a few more aftermarket ac kits for the HZJ7x , I have 1 12V available and 1 24v model.
Even though shipping cost have more then doubled and the Euro /USD is not in my favor I am listing these at the same cost as the previous shipments , next order will be higher unfortunately.
Here is the link of what to expect
Is this close enough to work on a 24V BJ75? I looked for your original thread and didn't find it. I think I asked the same question there, but it's been a few years. What's the total cost?
Dan
Dan
No the 1HZ and 3B use a complete different mounting system on the engine , kits are 2500$ (for now) and I can get a specific 24 v 3B kit for you and had 2 of those in this order but they are already sold.
I have a 14BT, compressor looks like this: (I have the compressor, and bracket on the engine, not sure if it works though...)
Not sure if we start mixing up parts what will fit or not , If you want to build your own kit I did bring a few of the underdash evaporator boxes which is the hardest part to get , you can make your own lines and use a universal dryer and front condensor.
Bump let's get these 2 to a new owner so I can start a new order for next spring
New inventory should be arriving in the US in May
I have ac kits for lhd
HZJ 70/73/75 24 and 12 volt
BJ 70/73/75 24 volt
LJ 70 73 12 volts square headlight model only
KZJ 70 73 77 78 12 volts
Limited quantities for each model available , next batch will probably be for 2023
Hello, have a 1990BJ70, looking for:
both outer front fenders
Both side mirrors
All the relays under dash on the steering column (12V)
Rear tub inside upholstery panels
front bumper
Thanks
I need a bj70 12v
I have 1 kit for a BJ7x on the way , I ordered it as a 24 volt kit but I might have a spare 12 v compressor to make this a 12v kit . What year is your BJ70 and what market does it come out off ?
Hi Joe looking for BOSCH Diesel Glow Plug Relay 333 402 520 and the
relays under the dash, ( flasher and the round relays )
For a 91 BJ73, 12V
Thanks
New inventory came in and I have kits for the following lhd 70 series
BJ70/73/75 3B 24 volt
LJ70/73/78 2LT square headlamp models
KZJ70/73/77/79 1KZT
HZJ70/73/75 1HZ 24 volt
Even though shipping cost has tripled I decided to not raise the prices on these , 2500$ per kit plus shipping from Texas
Joe
Update 7/22/2022
2 more kits available
1 for second gen with 2LT engine
1 for KZJ7x models
LHD ONLY
Both side mirrors
front bumper
Thanks
i have bj70 parts
