What's the need for head studs?
Superior clamping force, easier to torque properly without damaging something, reusable and waaay cheaper (even at ARP prices).What's the need for head studs?
Actually, that could be more clear.no, the opel studs are longer by too much. They work fine except under the cams. There added length contacts the cam sprockets and requires trimming the front Two studs.
WE NEED SUPRA STUDS WITH THE SAME THREADED SECTIONS AT BOTH ENDS BUT 6MM LONGER.
I don’t know how to make it any clearer.
Thanks for the info! Ideally the things are idiot-proof and do bottom out, so it’s not too challenging for future generations who thought everything would be electric or we’d have teleporters by then—but you’re right of course; they don’t HAVE to bottom out.You do not need to bottom out the stud to get the max strength in this application. The Supra studs will be fine for this joint like has been mentioned earlier in the thread some people do drop a small ball bearing in the hole to bottom the stud on.
There are a lot of factors to this but the biggest one is that you are using 200,000psi bolts into Cast Iron. Cast Iron with hole sizes 1/4" - 5/8" reaches max pullout force in 1.4x the diameter of the fastener. It is an 11mm fastener so as long as it is threaded 15.4mm into the block going deeper isn't really going to give you anything. Best thing you can do is ensure the threads on the fasteners and head are in very good shape and a tight match.
If you really think you need more clamping force you can have the block and head drilled and tapped to 1/2" but it is not necessary.
Some reading on the last 2 pages here for those interested.
Got it and passed along, thanks!The overall length of the stud needs to be 6mm longer. The threaded sections are fine as they are.
Ideally they should measure a new one and a stretched one. They are plastic region after all.Anyone have a decent-shape oem head bolt and washer I can send to my ARP contact, so they can measure the damned thing in-house?
Would there happen to be an update ? Im in the market for such atm.I think they just want to verify thread pitch and washer size. We might be getting close to a dedicated kit for our engines.
Did u see my post above?I just ordered a new head bolt and washer. Once they show up, I'll send them on to ARP, and we'll see what we see. Might take a few weeks to get the parts, as they're part of a larger order...
Yeah I took a look; thanks for the link! But they have no information on that page (probably so you can't compare prices). Could be a Supra set for all we know, there's no such P/N on ARP's site, these cost 'more' than head bolts, and ARP tells me they have no FZ set. So I'll keep on my present path, see where that leads, and report back...Did u see my post above?
Waiting! I'm building a FZ for my FJ40. I used ARP on my old Arctic Cat. They didn't make a set to my specs, so I called them. The guy said they had a set of custom studs they had made for someone that they returned unused. They were for another vehicle and were the exact specs I requested. Got them for $60. I kept blowing the factory head gaskets for some reason - ARP studs ended that problem. I think the Arctic bolts stretched over time under load/I just ordered a new head bolt and washer. Once they show up, I'll send them on to ARP, and we'll see what we see. Might take a few weeks to get the parts, as they're part of a larger order...
Which Opel kit? Are they the correct length, longer than the Supra kit?Done about a dozen rebuilds now with the Opel ARPs, no worries.
Cheers
