lumbee1
Native American
Installed a supercharger. It makes whistling noises.
I have an agitator dog and it didn't even require installationI installed these on our washing machine. Now I'm agitated.
80040 Whirlpool Washer Agitator Dogs
80040 Whirlpool Washer Agitator Dogs. Replaces AP3119063, 285612, 285770, 3109, 3366877, 387091, AH388034, EA388034, PS388034. Fits many models.www.genuineapplianceparts.com
Ok so when I just went back to test all the cylinders again I they all came back perfect...... must have had a valve slightly open the first few times I tested. It's been holding at this for 10 minutes now.Leak down day for the subaru
Cylinder 2 looks good
Cylinder 4...... Houston we have a problem
Maths says that's more than a 20% difference
Had to check TDC 4 times to make sure a valve wasn't open. Well I can stop holding out there is a blockage in the cooling system somewhere.
The good old days at Fugate ! makes me realize, I’ve never had a place to work on the cruisers.Speaking of wrenching, and of @lt1fire , here's an oldie I found in the memory banks today. @NCNole @forrest5000 back when I had a nice flat, covered place to work on junk.
Judging by the cleanliness of the tools, you basically just used the hammer. Did you try the sawzall?Never before has removing one suspension link resulted in so many 4-letter words. When you end up using all of these just to remove 2 bolts and replace 2 heim joints, it’s turned into a challenging job.
One of the spacers had basically became one with the lower bolt, so it had to be destroyed to get it off. New spacers are on the way and then it will finally be all back together and ready to rock ‘n roll.
never buy just one pack lolWrenching and ranting…together at last!
Hanging a small corner shelf in bedroom. It’s 1/8” panel so I can’t use the normal drywall stuff.
I bought a 2-pack of these wall anchors. How the hell did I miss the elephant in the room/package???
Unless Dollar General has something I can use, it’s 20 miles to Lowe’s or Walmart from here. I guess this project will have to wait until I’ve gone home and come back down here. And Sarah wonders why some things take so long to get done around here!
somebody got screwed......Wrenching and ranting…together at last!
It’s just diy’ier than your normal setWrenching and ranting…together at last!
I bought a 2-pack of these wall anchors. How the hell did I miss the elephant in the room…
