Run it through its paces with wife in tow. Could very well be a reset.
I bought this 2uz VVTI a while ago with the plan to swap it into this 80. It has 106k miles on it and the sticker on the engine cover says the timing belt was done at 84k miles. The engine has been stored inside and not run for 3 plus years. Anyone think I should swap the timing belt out again?
I have been doing some research on the VVTI version and I am leaning toward deleting the SAI system to reduce maintenance needs, clean up the excess on the engine and use the non VVTI manifold’s
Is there anything else specific to the VVTI I should address before installing it?
Starting with this.
Ditto on pulleys, idlers, etc. they were worn out when I did my wife’s truck. These can seize and cause some damage. In case you are interested Dennis, here is the parts I replaced. Olathe was cheapest to my door.I have replaced a lot of 2uz and other Toyota timing belts. I have never seen a belt that looked "bad"
Idler, tensioner pulleys, and water pumps are a different story, I have seen a lot of them that were junk. The VVTI 2uz is well known as an "interference" engine and would be trashed if it were to jump time more than a few degrees. If it were me I would go ahead and change the timing belt and all associated parts.
It this parts list for a VVTI? I haven’t done any research to k ow if these parts are the same for both 2uz versions.Ditto on pulleys, idlers, etc. they were worn out when I did my wife’s truck. These can seize and cause some damage. In case you are interested Dennis, here is the parts I replaced. Olathe was cheapest to my door.
