Once I finish out a few sets, I will let you knowSounds good, when can we start bringing our old ratty wheels down to get this done?
Do you plan to get the wheels sprayed with a catalyzed clear coat (Autobody shop, SprayMax can)??
That could be a possibility. There is a Powdercoater next-door. He thinks we should go with a acrylic powder coat clear, so we will try once it like that.Cerakote Clear maybe?
Cerakote - CERAKOTE CLEAR - ALUMINUM
Shop Cerakote CERAKOTE CLEAR - ALUMINUM MC-5100. Find the coating that fits your application. Choose from a wide variety of coatings with specific attributes and specialties.www.cerakote.com
I'll admit, it's cheating. I can't wait until they are finished. I'm doing my fourth set right now. A fifth set tomorrow. Trying a few different things along the way for finishing them.OH! Now the link works. Cheater Cheater you use a biga$$ lathe!
I thought you actually some crazy kraut space magic thing going on.
In my best Yoda
Impressive, that is.
The lay lines you've kept. Over-polishing the corners, you have not.
What sorcery is this that doesn't require a lathe?
We're using a fairly wide insert, could do a lower feed per rev. May take it lower and see the results. I think we're dialed in though.What inserts are you using? To get the rainbow effect you want to minimize the distance between cut spikes width, without wiping out all of the cut spike, so a really pointy insert at enough FPR to create a "diffraction grating effect". If you want them to look polished, go with a wide insert and a low feed per rev, it'll "wipe" the turned face.
Sent you a message. Would love to get the technical drawing or some dimensions on this wheel.We're using a fairly wide insert, could do a lower feed per rev. May take it lower and see the results. I think we're dialed in though.
I blasted them slightly to clean up the pockets. I think what made the second biggest difference is putting them on a huge flat vibrating lap that is supposed to be for pieces of granite. That made a huge difference in the pockets.Are the pockets blasted? that would seem to be the only way to clean them up.
Glad you asked. Here's what they look like after they are finished.What, if anything, did you do to the back sides?
Exactly. The powder coat clear on the inside will protect them for a good long time and makes them easy to clean up, inside and out.Nice. Easier to keep clean as well.
