Tell us about those post terminals . . . lots of these issues have come down to faulty terminals
Time for a new battery. Don't you have your winch isolated? If so you can eliminate that as the draw.
those terminals have a lot of posts on them . . . with the issues you describePositive is the old slee "upgraded" terminals, the onese before billet. They are really for a group 31 - I'm not running the negative one because it wouldn't fit. So it's a stock negative terminal.
Have any examples handy? What's the TL;DR;?those terminals have a lot of posts on them . . . with the issues you describe
At this point I'm mostly confident that the battery is the current cause no start issue given that I was able to jump / swap battery. But what I'm not sure of is if there is something causing draw, or again just total coincidence.
I am going on a wheeling trip to Sedona at the end of Feb and am looking for a smoking gun so I can feel better about it!
most have replaced with something elseHave any examples handy? What's the TL;DR;?
I thought I had a dying AGM after 7+ years in two rigs and I broke down and spent the money for a fresh one, and within a week I started having the same issues. Then I started to move my multimeter around on the various locations of the posts and was getting different readings, so I called Slee.The posts from Slee/SDHQ are faulty?
They said there was an issue with corrosion building up between the part that clamps to the battery terminal and the second part on top of that, clamping on each side. There wasn’t any corrosion visible on mine, but I removed it and sure enough, there was a little hidden corrosion. I filed it all really clean and put them back together. I ordered Slee’s newer billet ones and ran the old just fine until I got the new ones installed.
Hope that helps.
Yes I am still using the newer billet Slee ones. Probably overkill, since I don’t run a bunch of electrical accessories, but I have no issues with them.Are you still running the newer ones or did you move on to something else?
Hope that helps.
You’re just practicing patience and became more familiar with the starter replacement process to help the next guy out.Holy s***. @grinchy called it.
The inside of my terminal and the extension are incredibly pitted.
among my mud friends, I’m no longer convinced this wasn’t a wild good chase and I just preemptively replaced my starter.
Ordered a Warn VR 12-S
Bummer. When’s your next trip scheduled?Winch order was cancelled by amazon seller, not able to order from warn either
Probably a good idea to have them double check prior to making that commitmentNext big trip is end of feb to sedona but missing lots of opportunity for snow wheeling.
I found a vanlife place in Utah that has one. I asked the sales person to walk to the warehouse and double check lol. Crossing my fingers.
