- Thread starter
- #421
I had the truck backed in the garage to finish up swapping out the rear differential fluid. When I finished I pressed the start button and nothing.
After what was possibly a panic attack I popped the hood and checked the battery - 12.2v. I put the NOCO on it and after a very long crank it started.
I got the truck situated in the garage just in case and swapped in my old X2 power back in. Thankfully the truck started again.
Dudes omg
I’m going to be careful next couple of days just in case but hope it’s the end of the drama. I’m going to warranty out this new interstate battery next week. My theory is that maybe I killed a cell winching it in the trailer.
I dropped my interstate FLA battery off at a local interstate store and they confirmed that it’s discharged which gives me some peace of mind. They are going to try to de-sulfate it before warrantying it out.
In other news I’m on the hunt for a winch
I clearly exceeded the duty cycle on my APEX and it’s now dead. I started by trying to replace the solenoid as all of the cheap Chinese winches share the same one.
However the issue is the drive motor itself. I knew this was the case as I tested it first by bypassing the solenoid. But it was worth $35 to try it.
I am going to try to fish out the drive motor from the under side of my bullbar.
Leaning toward a warn VR 12-s. Amazing warranty on those and much better duty cycle than any of the other entry level winches.
