Very awesome
Nice work. You might want to consider putting a bead on the fuel line tubing to prevent them from slipping off. I use this tool by Graham. Made in the USA.
Updates on the build?
Strong work diving into that bird's nest of wiring.
That is why I like diesel swaps. 1 wire to run. Add a boost gauge and pyrometer and go....
Great build mate. Is this the Fuel pressure reg vacuum line in this pic?Thanks, much appreciated...
The Air Intake took a minute to figure out... I spent more time than I'd like to admit getting this together... I hacked up a number of boxes, plastics, couplers etc...
Right from the start, I knew I couldn't fit the "box" or "square" air filter in the 2uz into the 80. There isn't enough space with the battery box there.
SO I stuck with the 80 round filter (I kinda like it better)...
Zach also tossed in a tid bit to change the top hat to a 1fz style.. It can be cut down to a round interface vs the 3fe square interface... The boxes are the same, just easier to adapt...
I started hacking up all pieces in my parts pile... 3fe intakes, LX intakes, anything 3" ish hose related and started piecing things together...
In the end here's my final setup:
The back side of the vacuum lines routing.. that also took a minute to get right..
Would it need manifold vacuum to work properly, not too familiar with the 2UZ
I'm pretty jelly.Hot!
I think it's the Birfields that wear fasterSo I got the rear locker working and moved on to the front axle... it kinda was a rush job to get it done for this past weekend's club meet..
Unfortunately, the front locker isn't right.. I put it back together and everything seemed to check out but it's not locking into gear.. gotta figure that out again...
I also took a few shots of my axles.. I've been running Chromolys for over 10 years and gotta be around 100k.... but I'm not see the wear regarding a "softer" metal axle? It's an AWD truck and always heard chromoly should should wear out.. granted maybe it's the threads?
Ahh you mean like the inner cage/bearings?I think it's the Birfields that wear faster
YepAhh you mean like the inner cage/bearings?
Yep, I also haven't heard any clicking or saw any major wear... I cleaned them out, regreased them, and put'em back on...Inside the cup is where my oem birf was pretty worn and I think the reason I broke a birf.
