What Did You Do with Your 80 This Weekend? (72 Viewers)
Nice to be clocking some miles with gas prices going down.
Replaced all the weatherstripping on my front and rear doors today.
The doors make a noticeably more secure "thud" when I close them, which is a nice added advantage outside of keeping the elements out.
Where’d you get the parts?
@bonestock I've had these pieces in the garage for a while, but they are readily available. I regularly buy from McGeorge, Toyotapartsdeal, or Partsouq.
If you want the parts numbers I still have everything. Shoot me a PM.
No it’s stock - I try to keep oem as much as possible
wow must have something really wrong on mine then !! or the bulbs are not stock. I did replace them but not with OEM just normal light bulbs the difference is quite big tbh. Maybe I missed a few or something, the needles are not even visible in my case.
First batch of water proof connectors arrived for my external lights
10-4. Just thought I'd ask incase there was somewhere cheaper than the others. This is on my radar. I like partsouq personally. Thanks for the reply!
I'm doing this in the summer, after the PNW rain season has passed...and also replacing the carpet and adding the sound dampening/heat shielding.
Heatwave Pro from Second Skin worked better than expected when I installed under my carpet. They'll give you a discount if you tell them you're a MUD member too.
Awesome! Thanks for the insight! I'll add that brand to my spreadsheet.
