There are a couple of ways to deal with a broken tap stuck in a hole:
With oxy acetylene, heat the tap until red hot and then cut off the fuel and burn out the tap with oxygen. You may need to increase the O2 pressure to keep the burn going.
Without OA. Heat the tap with MAPP gas until red hot and then squirt water on it to rapidly cool it. Then smack the cooled tap with a drift punch and a hammer. It should shatter like glass. This wont hurt steel or cast iron bacause they won’t get hot enough to harden and get brittle.
Grinding it out with a diamond burr might work, but it will be slow going and it is hard to keep it centered and not oval out the hole.
