OMG, is there a way to do it without doing the wheel bearings/ preload and all that stuff?
Nope. It's all or nothing, hands all up in her guts.
Yes. Pull the trunnion caps and the knuckle seals and stuff.OMG, is there a way to do it without doing the wheel bearings/ preload and all that stuff?
I have zero experience with lockers, but from what I've read they often need some axle rotation to engage. Did you rotate the front drive shaft?I tried to put the locker on (car in run, not on) I heard it actuate, but wouldn't lock (rear either)
Been there done that. Chewed through the housing and spewed out oil all the way home. Couldn't figure out where the burning oil smell was coming from.A little more force and that diff housing may have been pushed into the ring gear.
The last 8 hours of my life
View attachment 3184144Sometimes you just need to walk away. You well have a hole new out look in the morning
