- Thread starter
- #121
Had an hour to work in the garage this morning, I had to make the cuts a little deeper, then set the caster to 5*. I had the same caster angle on my last 40, it drove and handled amazing. I will open up the cuts and make a couple of passes with the welder. Before the housings go in for sand blasting and powder coating, I need to weld on the lower shock mounts and steering stops.
