On the topic of using rollers vs spraying for the frame. I contemplated this a ton but realized how much gap there is between the two interlocking C channels so I decided to go with a foam roller because it allows you to squish the paint on the inside and have it flow between the sections. You have to flip the frame to allow gravity to do its job. Much better than spraying. You would never get paint into the gaps if you spray it
