- Joined
- Feb 10, 2002
- Threads
- 550
- Messages
- 44,792
- Location
- Canton, Mississippi
- Website
- www.seeandeatms.com
Bump…..anyone want a parts 62?
Where?Bump…..anyone want a parts 62?
He lives in Madison MS. Nice guy. Impulse buy. Worth the money in partsWhere?
Where are the pics?He lives in Madison MS. Nice guy. Impulse buy. Worth the money in parts
Are you in Idaho? Not really worth shipping. I posted 4 pics above. Local deal. IWhere are the pics?
The 4* caster shims made a huge difference. Thank you Nolan!Finished off @WharfRat ’s lift finally with some 4* caster shims from Georg.
Also he sent us some reman loaded calipers for a brake upgrade
Smokey is ready to ride again
Can’t believe you parked that out front
ZF....Can’t believe you parked that out front
All they need to do is prove they drove it through the shop at TLC in NC, and apparently, that will up the price a minimum of $50k
for the nice people out on the forum
are there any options on running a GM steering gear on a FJ60 ? Not talking about chopping the frame or anything.
Once again I have a steering gear that looks like someone dipped it in p/s fluid (not leaking at the hoses or the hose fittings). This is about the 3rd or so interaction with the steering gear since I've owned my truck (1986 FJ60).
I though I read somewhere ....that one of the 80 series steering gears will swap out on the FJ60. I don't know if thats an improvement in quality or worth doing in general.
Short answer....tired of screwing with the steering, want to fix it and be done. I run a PSC p/s pump on my 5.7 vortec and have a cooler and remote resivor....p/s works fine, even now....but the gear is sold covered in fluid...(pisser). I don't drive my truck much at all and don't abuse it...., does have 35 inch tires.
Am I doomed to replace the steering gear every 3-5 years... Just want to get the &^%$ fixed... I though I was getting close to cover major issues and this thing shows up as a problem. Present steering gear is a used one (re-bult...and I forgot where I bought it, but power wise its been fine and still is fine....except for the leaking)
