Busy with the frame. Sandblasted, chemical stripped out all the overlaps, pulled it straight, repaired a crack, zinc phosphorous coated. Planning to start painting next weekend. There was a 3/4” diamond rail to rail so it didn’t really need to be pulled straight but I’m this far so why not. The crack repair isn’t beautiful but it’s drilled out and I’m confident my weld is solid. it will be like it never happened once I paint. The zinc coating gives it a dull texture that will bind to the epoxy primer.
