Anyone have info on the valve stacks supplied directly from King in their 2.5 OEM shocks? I haven’t been able to get info from any of the custom tuning resellers, I just want to soften them up and order the valve stacks prior to pulling them apart.
Last I checked, he charges about $250 for his time to answer questions like this.Call Ben at Filthy Motorsports, they carry the parts snd have the knowledge to help.
I find that surprising. However, I'm not sure he would charge you for this if you order the replacement parts through him.Last I checked, he charges about $250 for his time to answer questions like this.
Thanks for posting.For anyone interested... spoke with KING and this was standard valving without compression adjusters for the 2.5's
Fronts
Comp .012 .012 .008 flutter .015 x5
Rebound .012 x6
Rear
Comp .010 .010 .008 flutter .015 x4
Rebound .012 x6
Wheeleveryweekend tunes Bilsteins and Kings. I believe.Scratch that last comment….Accutune DOES NOT sell custom shim stacks, I grossly misread their sites information and they only sell shims like everyone else, you buy a stack of 6 (or a multiple sets) in every size you plan to use…looks like there isn’t anyone who I’ve personally found with actual experience tuning KINGS for an LC200.
Here is good read to start.
Props to you for tuning, most just buy the OEM kit and think its the best they can get. A tuned set of shocks at all 4 corners rides like a dream! AHC is ALMOST, ALMOST that good IMO
Tips For KING Shocks Owners - Ride Quality
DISCLAIMER: I just have to mention that what I may consider something that works, may not work at all for you or may not be effective for your application. So this is just to get you thinking about your setup and what the issue is or how to optimize it for your needs. Some of these tips are not...forum.ih8mud.com
Eibach is always the go-to, they have never not had a solution I was looking for. I’m not positive they make the springs for KING, but if I were a betting man…My rig is light, an ARB twin is the only extra weight I have in front.
Stock LC200 front springs are 500#
King LC200 2.5 standard springs are 600#, and I had the preload backed out as far as possible.
No matter what I did to twist up the truck, on articulation I could not get front bump stop contact. Meaning even their base rate springs were too firm to use all of the travel the shock and geometry should allow.
With some additional weight up front it would work great, and that was probably their assumption for people running that suspension, but in my case while I gained 2" of down travel from the front shocks, I probably sacrificed a half inch or more of up travel.
King didn't make a 550# spring in those dimensions, but that would have been perfect for my light build.. Eibach does, however.
