2mbb, thanks for all that info!!! Sure appreciate the help. Mine is leaking on the rear drive shaft where it meets the transfer case.
Did this stuff work for you? I’m not finding a whole lot of options.Anyone running this gear oil? Doesn't look to be synthetic. I assume that is still ok?? Thanks for the help!View attachment 2925620
A straight gl5 in these would be about the worst thing you could do....mud water would be a better option.Did this stuff work for you? I’m not finding a whole lot of options.
This is why I am inquiring. Maint. manual says GL-5. People on here say stay away from it. I’ve searched the forum, I haven’t reached the inner bowls yet, but I’m not finding anything definitive. But the mud water suggestion was very helpful.interesting.
its generally stated the gl5 is bad for yellow metal
I really appreciate the insight!!I generally stay GL5 in the Diffs, no yellow syncros and easier to find GL5 Mobil 1 that's formulated for higher shock loads, then I use GL4 for the Trans and T'case (sta lube or GL4 synthetics in the 5 spd).
The main difference btwn GL4 and GL5 (modern) is the amount of EP additive. GL5 is generally not recommended for a gearbox because the high amounts of EP additive for shock loads - usually Sulphur and Phos compounds that don't play nice with yellow metals.
I didn't read thru this thread so don't know if I'm repeating myself or others info.
It's more important to change these fluids often than it is to use expensive synthetics.
