Dang same here, bent my upper link bracket a month ago causing the axle to twist, got death wobble so I parked it, but I also blew the 8 inch on this obstacle right after that. Now I wait for a custom 9.5 front housing
Those Methods have a little bit of offset, which is allowing them to clear fine. I assume you're running 2.5" spacers in the front?Took mine out last weekend , grenaded a hub, lost a front caliper (thank god only go going 5mph cause it locked the wheel) and ripped the front sway bar bracket off the frame. I added caster to make mine stable. Now does 80 pretty easily. Are your wheels contacting the spring buckets? Mine are very polished now.
Your truck is so badass. Tons are definitely the way for anything over 37". Hence why I stuck w/ boring little 35's.Dang same here, bent my upper link bracket a month ago causing the axle to twist, got death wobble so I parked it, but I also blew the 8 inch on this obstacle right after that. Now I wait for a custom 9.5 front housingView attachment 3132157
I've heard mixed things, but the fact that I had violent death wobble w/ the plates, vs no death wobble post plates, is enough for me; even if just anecdotally. The truck drives great now. The plates are the only factor that has changed since.That doesn't make any sense. Extra caster will only make it drive better, not cause death wobble. My FJ62 that I daily drive has around 6.5-7.
You shouldn't even need to go to an alignment shop to check that. A simple digital angle finder on top of the steering knuckle bolts will tell you your caster. You have something else wrong.
We cut the factory 100 line where it met the pump and used an 80 steering box fitting. I took it to a local hydraulic shop and had them make a custom line to my measurements. That part was pretty easy.How was the replacement ps pressure line made? Is the return a simple barbed fitting with a line back to the reservoir?
I can't claim to know much about a 105 frame, since I have never seen one in person. I modified a 100 frame by fitting 80 suspension components. I am probably not the best person to address your question. It looks like you have both a 105 and an 80, so I would argue you are in a good position to find those answers.Sir, you are undoubtedly intimately familiar now with the differences between a 100 and 105 frame--probably more than just about anyone, anywhere.
I am readying my 105 for transport to Canada and at the last moment have had the notion of putting a factory winch on it. I know where I can get a new 200 series winch with mounting plate and I actually have an 'ok' 80 series winch with mounting plate, but what I am having trouble figuring out is which would be the easiest to fit on a 105? A factory 80 series winch or a factory 200 series winch. And just to add another level of noise, I also can get a new 70 series winch with mounting plate!
If you can throw some light on this question it would be greatly appreciated.
Well that is a fair point. At the moment I am completely without access to a place to take things apart And my parts, including an 80 winch, are inaccessible. Just a set of unfortunate circumstances. I do thank you for the reply. I think I will crawl underneath with a tape measure and see what I see.I can't claim to know much about a 105 frame, since I have never seen one in person. I modified a 100 frame by fitting 80 suspension components. I am probably not the best person to address your question. It looks like you have both a 105 and an 80, so I would argue you are in a good position to find those answers.
Thanks! Road manners are good for the most part. It does tend to wander a bit, but that could probably be addressed by installing a steering dampener, which I haven't gotten around to yet. Overall, it drives just like a wide 80 series with a 4.7. I'm really happy with it.@John Young here are some frame diagrams to show the difference between 80, 105, 100.
SFA 100 series - How many? - https://forum.ih8mud.com/threads/sfa-100-series-how-many.889922/page-4
@UZJ105 congrats on getting this completed been looking over this thread and others for several days as I’m seriously considering doing this with mine but I wouldn’t go with the TT kit. Have you taken any long distance travels with the swap and how are its manners on the highway?
No check engine light. I used the Marks 4wd ABS relocation kit since I am running a 4wd part time kit. The kit relocates the sensors and comes with a toning ring that mounts behind the brake rotor. I went through all that work, to wind up ripping the ABS wires on a trail. I've now driven thousands of miles w/o operable front ABS sensors. The ABS light is on, but I haven't experienced any ABS related issues.Curious how you handle the electronics etc doing this? I skimmed a lot of the post but not fine tooth comb, sorry if you mentioned. Check engine light? Did you use an 80 abs modification?
We stopped keeping track of the hours after the first 3 clocks wore out. After that we started counting growth rings on the trees that were harvested on my property and referencing one of the rings as the year we set sail on the project. When we finally finished, we had to file paperwork with the local historical society in order to remove a historic landmark.How many hours did that take you? 100 ish??
If I recall correctly, I think we estimated conservatively around 240 hours between @AJR and myself. We worked on it every weekend for 4 months; Friday afternoon to Sunday evening. Lots and Lots of grinding. And then more grinding.Following along ... need to get some mileage out of the parts I just put in but when I can get the logistics / shop / people in order I am gonna pull the trigger to SAS. How many hours did that take you? 100 ish?? Thoughts on keeping ABS etc?
Thank you SR5. Very helpful. I will spend time looking at frame diagrams and learn what I can.@John Young here are some frame diagrams to show the difference between 80, 105, 100.
