Guessing they might not be in Romania…?
I couldn't, either. Silicon was the other alternative to waiting three weeks to get them from partsouq.Ok, I can't stand it any longer.
What's the point? These gaskets are readily available and cheap. What am I missing?
Weekend again.
Going further.
Maker attitude... time losing, quite often, but that damn good feeling worth every minute.That's cool. When my wife got her cricut machine I thought it would be good for gasket making.
I am still using a ball peen hammer and a piece of cereal box.
I did that on a subaru outback I used to ownPulled the anti theft module from under the dash. No more random alarm going off at 2am!
Digging the slick top! She cleans up nice!Well, I got a little too sassy apparently last night. Two brand new alternators and a third on the way tomorrow. One day, I swear to sweet baby Jesus. I will be done with this one damn job!
Thanks! That was where she died in the liquor store parking lot last night. I didn't even get to use the fancy drive-through window. The guy trimming the trees was nice enough to give me a little jump this morning. I think she might just be yard art at this point. Haha, I was able to find the half-assed rodent damage repair the PO had done and replace that as well. Hopefully, the third alternator is the charm.Digging the slick top! She cleans up nice!
This is a super cool idea! Don't get discouraged. I think if you were to add a secondary at the bottom it would more effective for bracing and run it only inside like straight down from the top right screw along that tan plastic. Hell, even remove that plastic and replace it with your metal addition. I have a complete dashboard outside of my vehicle if you need some photos or recon let me know.Might be a lost cause. But I’ve started on this project. Wanted to see if i could make a phone/device mount that spans across the top of the screen and be attached using the existing radio bolts on top. If it wasn’t for Lexus build quality it would be a lot easier. The gaps between the vent and the HU bezel makes it an extremely tight fit. I’m using 1/8” aluminum wondering if i go with thinner sheet metal will it still be as sturdy?
Love to get some input from you. Also not having a metal break makes the bends more rounded would love a tighter bend but it's aluminum so not sure if that's possible.
If I can get the mounts done right then I would tie the two brackets with a strip of metal, that way I can drill holes in top of that span to mount things like the RAM uni-ball to attach phone mounts etc on top
How long have you been running with cracked manifolds? How much weld buildup did you do?374K on odometer. This week:
- New brake lines and speed bleeder valves
- Brake fluid flush
- New sway bar bushings forward and rear
- New sway bar end link bushings
- Pulled exhaust manifolds and welded up cracks
- New exhaust mani studs, nuts, gaskets
- New front axles
- New wheel races and bearings
- Turned front rotors
- New upper and lower ball joints
- New outer tie rods
- Oil change
- Removed about 5 lbs of 22 years of grease and dirt.
Mine does not make any ancillary noise. It’s been hooked up a year, approximately.Any of you guys with a BT45-Toy unit for Bluetooth have a constant whining/feedback noise that is most heard at low volume or when song changes? Can’t tell if my unit is defective or not
