- Joined
- Apr 14, 2004
- Threads
- 1,391
- Messages
- 35,257
- Location
- 818-953-9230
- Website
- www.marksoffroad.net
- Thread starter
- #21
Well I guess you’re up.Interested in the rear ConFerr Bench Seat. Not sure where I am in that line.
Woohoo! I’ll give you a call in the AM.Well I guess you’re up.
Good call on the bumperettes. They are easily the straightest used pair I’ve ever run across.I would like the bumperettes and the support/backing plate for the side mirror withe the bolts and washers.
There are some red belts. But I’m not sure they’re stock. Got heyre on my list of things to pull today.Does it have seat belts? Are the toolbox latches there? This may be an odd request, but I could also use the 4 rear wheel cylinders if they are in rebuildable shape and TEQ.
Whatever happened with your hunt for a WP?
Jack, handle, hook and tire iron: $300. For you, a regular customer, I will cover shipping.Interested. What do you need for the jack and tools?
Will this fit in a 1971 fj40?? I’m new here sorry.66 front seats, solid. $650obo
If I remember correctly, the inboard leg on the passenger is slightly different. I’m going back over 30 years, so the memory is a little fuzzy. Maybe 3/4” shorter.Will this fit in a 1971 fj40?? I’m new here sorry.
Thank for the info, I also need those seatsIf I remember correctly, the inboard leg on the passenger is slightly different. I’m going back over 30 years, so the memory is a little fuzzy. Maybe 3/4” shorter.
I might find out next week, as I plans to call a local with a’71 that needs seats. But if they work, chances are they will be sold, which will save me the headache of shipping.
Check out my signature line; I know where to find’71 seats.Thank for the info, I also need those seats
