My rig has developed a gradual crack in the normal spot, so I started searching for bracket kits.
This is what I found & most likely not every kit available, just got on the web found this info:
I only found one Made in the USA so I went with Delta VS kit.
Delta Vehicle Systems - DeltaVS Frame Supports - Weld It Yourself Kit - PREORDER - https://www.deltavs.com/all-products/deltavs-frame-supports-weld-it-yourself-kit
The rest of the kits are from AUS, some have more brackets to address the front panhard cracking on the frame.
Toyota Landcruiser 80/105 Steering Box Mount Repair Kit - PSRLAN-031 - PSR Quality Offroad 4X4 & Racing Products
Buy the Toyota Landcruiser 80/105 Steering Box Mount Repair Kit from PSR
www.performancesuspension.com.au
80/105 Series Land Cruiser Steering Box / Pan Hard Braces - https://refab.com.au/shop/80-105-series-steering-box-and-panhard-braces/
80/105 Landcruiser - Steering box brace kit | Rampt Customs - https://www.ramptcustoms.com.au/product/80-105-landcruiser-steering-box-brace-kit/7
80 & 105 Series Steering Box Chassis Repair Plates - Black Mamba Racing - https://www.the4wdshed.com/80-series-steering-box-chassis-repair-plates
Here are some threads discussing the how to do the repair, plus a talking about not welding a vertical weld on the frame.
Cracked Frame - https://forum.ih8mud.com/threads/cracked-frame.273182/
Cracked Frame Plate Template - https://forum.ih8mud.com/threads/cracked-frame-plate-template.1090380/
Theory on preventing frame cracks around steering box and panhard bracket - https://forum.ih8mud.com/threads/theory-on-preventing-frame-cracks-around-steering-box-and-panhard-bracket.1255203/
How "NOT" to caster correct, panhard correct your 80 series with J springs - https://forum.ih8mud.com/threads/how-not-to-caster-correct-panhard-correct-your-80-series-with-j-springs.531962/
