Unicorns are running wild here for sure !
I have your standard horse I guess.heck ?
TWIN UNICORNS are running wild in my back yard right now !
View attachment 3111149View attachment 3111150View attachment 3111151
You will like the sniper once it gets self-tuned. I did have to make a few minor manual adjustments to the decel fuel cut-off as it tended to lean out on decelerationGetting closer to a better running 2F. Working out the small kinks but we’re 98% there. I’m stoked.
Hard times will focus the mind. Had to say goodby to my Labrador. She almost made it to her 15th Birthday. My reaction was to lean into my emotional support land cruiser.
Finished stripping everything down to a bare tub
Rode it like a bull outta the garage
Pulled the drivetrain
Prepped for blasting
Holy Wow there’s some rot and bondo cover up
View attachment 3112521View attachment 3112522View attachment 3112524View attachment 3112525
Decided the combo of rot, bondo and bad patches is just not acceptable. Im going to cut the rear of the tub off, retain only the lip where the hardtop seats and rebuild the whole thing
Discovered the driver front motor mount was broken
Started fixing the bent sections of the frame
Diamond by about 3/4 inch, level otherwise, will pull this out
Fixed a crushed spring hanger. Got it to exactly 82mm and back in round
Wonderful welding skillzz by the PO on this crack. Lots of heat, hammers, clamps, wrenches and welding and I will have this sorted
View attachment 3112531View attachment 3112532View attachment 3112536View attachment 3112535
Man, really sorry to hear about losing your Lab. It’s tough for sure. You get so attached. Leaves a hole. Way to focus all that emotion though . You got a ton done! I’m impressed! And inspired!Hard times will focus the mind. Had to say goodby to my Labrador. She almost made it to her 15th Birthday. My reaction was to lean into my emotional support land cruiser.
Last couple of weeks I've been scraping and sanding down the underside of my FJ40 and finally got to paint the cassis and other parts. No more rusty looking undercarriage!
