tucker74
Moderator
Here you go man, think there is a Gladiator under this hot mess … you can do better!
Quite the collection.
Does this bed make my ass look weird?
For hauling beer kegs. Like what Migs used to have on her 40. @bottombracket remember?Hello,
You could squeeze a small crane in the space between the cab and the tray.
Just a suggestion...
Juan
Ferrari cranes , agricultural tractors and other industrial machinery are a common sight in EuropeHello,
Many moons ago, a company located near where I used to work had a 75 Series pick-up/ute with a crane, just like I described above, behind the cab.
I can search my files to see if I still have a photo of it.
Juan
Edit: I found some. Low quality cell phone photos.
750-kg / 1650 lb crane. As you can see, the brand is Ferrari. Odd.
Holley makes a 7” round LED headlight replacement for old vehicles, they come in 3 different colors. $399 for a pair. They are short enough to fit most old cars, unlike all the other funky looking LED. Thinking of going this route,Lots of good options, thank you hive mind.
The IPOR looks stout AF but is out of stock. Slee is in stock and reasonably priced. It looks like an option thst would be bolt up, just re-drill the holes for the crossmember in the appropriate locations. Looks like I could fit the nuts onto the bottom of the transmission and not even have to re-drill any mounting holes in the frame. Would require some calisthenics to drop the transmission, but that would be the fastest option.
Sectioning the crossmember and rewelding mounts to frame is cleanest and sexiest but I have to draw the line somewhere.
The hardest part is this project comes into the homestretch is deciding how far to take everything… Spend money on bomber suspension? Or a thousand bucks on Aussie LED headlights? Upgrade to power windows? So many options, and all are good.
Slee is looking good.
