- Thread starter
- #21
A quick update. The battery trays ordered look too big and even cutting them will probably not fit the said Group 24 batteries. I checked various things with the battery removed and it does look like any thing bigger than the PC1200 on @r2m build will most probably not fit. The max space available is around 14 L x 10L x 9 H which needs to fit the batteries and tray etc. Ultimately it does look like the Dual battery kit is not a bad idea conisdering how much custom work will need to be done and the component and labor costs. I think for now, I am going to upgrade to a 27 group battery (larger and higher capacity for winch if needed) as the starter and look into mounting the home battery in a different location. Maybe the Li battery in the back behind the plastic with an inverter and dc to dc charger. Just contemplating.
