Play Madona Vogue. “What are you looking at” phrase normally pans from left to right. With the RT over Bluetooth audio it pans from right to left.How can you tell they are inverted? I haven’t noticed that.
That is amazing you noticed that!! Incredible perceptive skills.Play Madona Vogue. “What are you looking at” phrase normally pans from left to right. With the RT over Bluetooth audio it pans from right to left.
Ok, so to close out my solution here this is where I ended up and it's good enough for me to run with for a while.Thanks for the help guys. I did this all and it still is only playing music through the RT system. Grrr...I wish it would work properly the way it was intended with the BT transmitter.
Just to be clear, I do have it connected for Phone and Media to both RT and LC. Pushing play on the LC only gets the music to start and stop on the RT system. Also, phone calls seem to bounce between RT and LC as well, almost as if they are fighting.
I did but had an Autosound place do it. We installed a switch to power in and off on command… sorry no more details but it was $80 easy bucks…Has anyone hardwired the power for this unit? If so can you list the items you used and some pics of your set up? I plan on hard wiring the power and was looking for some ideas.
Order a new one return the old one with the new orderI just came back in town not too long ago.
Haven't had a chance to even play with my Road Top.
Today, I installed it and try to use it for the 2nd time.
Unfortunately, I hear the fan working but when I power up the unit, the screen is just blank.
I pressed the left side of screen hoping it was on/off issue but same dead screen.
Eventually, 3~4 power down and on finally turns on the screen.
Anyone with similar dead screen issue? the fan was working so I know the unit getting the power even nothing appeared on the screen.
Very frustrating. does anyone know how to get in touch with the mfg service and what's the warranty period?
Unfortunately, 30days Amazon return window was closed now.
LOL… that’s a pretty effective solutionOrder a new one return the old one with the new order
@jefo13 Not sure what I did, but my text messages are now reading through the LC audio and not the RT box. Wasnt expecting that to happen, but Ill take it.I took some pictures to better describe my setup without connecting RT to the 200.
Here is the BT menu on the 200, showing only my phone connected to both phone and media profiles...
Here is the RT showing my phone. This says disconnected because CarPlay only uses BT to "handshake" and it actually connects through Wifi
This is what a phone call looks like. No matter how the call is initiated, it routes through the 200's sound system as usual
Here is what Media looks like. If new music is initiated on RT through Siri or music app, it may start playing on the RT, all I do to reroute to the sound system is hit the play/pause button. This rarely happens to me as I usually don't initiate Siri via the RT, but by saying Hey Siri or Using Siri eyes free button (hold answer call button on steering wheel)
I hope this makes it more clear.
PS Notice that some times if you leave your car while running for example and you take your phone with you, upon returning the RT may not immediately connect, this happens to me even in my Ford Edge OEM CarPlay but it's easily solved by toggling the RT unit. On my Ford, I have to turn off the car...
Does the EC unit work with the factory head unit? I think I have seen that in some videos. I would have gone that route and probably will soon. Mainly because it is less clutter in the windshield area. I guess I can always mount mine in a different spot but I guess you want it fairly visible.So everyone is still happy? Getting ready to pull the trigger on this over the EC unit. I’ve had issues in the past with them and not been happy with support and quirks
I really like mine. It has some quirks (dimming, wires exposed for power, can't get BT to work for sound so I'm using the 3.5mm audio out), but it connects wirelessly to my android phone every single time and still allows full access to the stock HVAC controls without switching systems.So everyone is still happy? Getting ready to pull the trigger on this over the EC unit. I’ve had issues in the past with them and not been happy with support and quirks
If you also have the V2, then Yes please send me update.I was able to update the unit with the software package they emailed me as well. I'm not sure there were any notable updates in the unit that I can see at this point. I'd be happy to forward along to you if you would like.
