I've put a few thousand miles on the truck since replacing the solenoids. Not a single issue to report.
Just google the part numbers in the first post. The first amazon hit will get you there.
is there a 4th solenoid links are only showing 3I did my swap today. Shifts like a champ again. Here are the amazon links for the solenoids.
Amazon product ASIN B071J52B8FAmazon product ASIN B0719T2W9TAmazon.com: Isuzu 897202074 Solenoid, Timing (2 Hole: Automotive
It took about 6 quarts to fill it back up. I had the wrong filter and gasket so I left the old ones on as they looked fine.
Yes 4 solenoids.is there a 4th solenoid links are only showing 3
Shift 2 and Timing use the same solenoid. Only 3 different part numbers for the 4 solenoids.
So will I need 2 of the
Isuzu 897202074 Solenoid?
Website part reference: FSM reference:
D49421A Solenoid, AW450-43LE (RNJ) Shift 1 --- Timing Solenoid
D49422A Solenoid, AW450-43LE (RNJ) Shift 2 --- No. 1 Solenoid
D49422A Solenoid, AW450-43LE (RNJ) Timing --- No. 2 Solenoid
D49425A Solenoid, AW450-43LE (RNJ) Lockup --- Lock-Up Solenoid
Not many OEM diesels in the US; maybe one of the Aussies can help with that question.Dear all,
I have a question in this regard. My '95 Land Cruiser 4.2L turbodiesel with automatic gearbox is indecisive when shifting from first to second gear. It shifts up, down and finally up. I think this could be the solenoids but am not sure. I am thinking to follow the suggestion in the first post to order a set of solenoids at cobra transmissions. I am just wondering if the gearbox for the petrol and diesel engines are the same? But perhaps someone has a better suggestion about the gearbox issue that I'm experiencing?
Thanks!
NopeSo I own a 1997 Land Cruiser and don't think I have the A442F transmission. Will these Isuzu solenoids work for my 97?
I think I found the answer in that these solenoids will not work for my 97 which is a A343 transmission. Bummer. I thought I found a good fix for the occasional downshift issue I am having.So I own a 1997 Land Cruiser and don't think I have the A442F transmission. Will these Isuzu solenoids work for my 97?
Well I took the plunge and ordered solenoids as well. Hope to have them in soon.Well, color me shocked. I received the solenoids today, they are all genuine Isuzu parts!
Guess I know what I am doing this weekend.
Mine is still shifting great after almost 2 years.Well I took the plunge and ordered solenoids as well. Hope to have them in soon.
