Ok so i don't know if this has been covered in the thread so here goes.
I know a lot of you guys are in cold climates so may want to retain the 24v starting (even though it probably makes bugger all difference). Charging two batteries in parallel will always result in one battery crapping itself eventually. This happens all the time on HDJ81s. Most no start conditions are because of that.
You can delete the 24v solenoid thing very easily and run one start battery (LH) and have a house battery in the RH tray. In fact you don't even need to change the starter, it'll still spin on 12v. Add one jumper in the plug that connects to the timer and you're away.
My set up is 2 identical "all rounder" batteries, they're lead-calcium, 110AH (yeah right) 660CCA. I swap them over every 6 months or so to increase their lives. One is charged by the alternator and one by a DC-DC charger.
This way you loose the solenoid (that can and does fail) and a load of nearly 30 year old wiring. Truck still starts just by looking at the key.
I can snap some pictures and do a write up if people are interested.
