Nice! Did you go swimming?Explored the tippy top of Michigan’s UP. View attachment 3064826
Out with the old and in with the new. Not pictured is the new radiator.
View attachment 3065673View attachment 3065672
Sure did! Water was numbingNice! Did you go swimming?
That is IMO the most important baselineing for our rigs other than oil, and plugs.....been down this road many times and dealing with cooling issues on and off the trail is a real PITA.Out with the old and in with the new. Not pictured is the new radiator.
have done this mod before Joel's kit, and has been over 3 yrs now.. same location. Only gotten in the way of rocks once and straighten fins, G2G!And a power steering cooler also from @NLXTACY
I was lazy and didn't remove the bumper to install properly. 2 out of 4 bolts, and a clamp should be good.
I can relate, this was me a year agoOut with the old and in with the new. Not pictured is the new radiator.
Look awesome! Where is this at? Would you mind PMing me a pin?Explored the tippy top of Michigan’s UP. View attachment 3064826
1657166030 - HOSE, RADIATOR, NO.1Dang, is that a full 100% cooling system replacement?
Smart move replacing it all while the parts are still available.
I have pretty much decided I will be doing this sometime in the next year or two.
It sure would be nice to have a complete parts list for every cooling system part.....
How much money is on that table? I'm looking at a new 80 that has been sorely neglected in every hose and gasket. Hard to imagine doing it all in one fell swoop.Out with the old and in with the new. Not pictured is the new radiator.
Man! Talk about isolation…
Where? I’ve been meaning to get some chains. They’re a necessity for snow wheelinReplaced all the dome lights (including two factory domes added to the hatch) with amber LEDs. Wasn’t going to bother posting anything so simple but I am really happy with the switch from white LED. It gives a warm glow that is much more pleasant as the old stock incandescent were but the output is significantly improved.
Seen here with one on in camp, the desired insect prevention also worked well.
Also grabbed a summer deal on chains and had to test fit everything on a hot afternoon.
Amazon used section. They were all brand new but had been returned. Not a shelf stock item around here so I sent some more money down that big riverWhere? I’ve been meaning to get some chains. They’re a necessity for snow wheelin
