Basically not gonna happen
Wow, that would be awesome! If you do it you might as well also build a kit for the early 100s that use the 4spd auto, tthat market would be huge in the USA. Looking forward to this coming.
Can you tell me more about this, "We have the same transmission in 80 series here in Australia that we have done the conversion for but they were all Diesels."? I have a RHD diesel 80.
Maybe this guy can help us with this project.
I am planning to run my a343f off my Haltech ecu if I can figure it out. Now I am thinking I should try to figure out the 750 instead.
Probably because many need obd2 to pass emissions. Lots of guys in oz are going stand alone.Is there any particular reason that more people haven't replaced the factory ECU with an aftermarket one, like Megasquirt or Haltech? I would assume that this would give access to more modern and sophisticated tech, as well as easier integration with different transmissions and whatnot, but maybe I'm overestimating the abilities and customizability of the aftermarket ECUs.
