The 4x4 always seemed way overkill. 2x4x1/8” would be plenty unless you plan on pivoting your rig on rocks against the rockers, then you might want to step up to 1/4”. The heavier the material the more weight it is pulling against the lower door jams and spotwelds and floorpans. One of the reasons I just capped my rockers short with 14ga sheetmetal and will be running frame mounted rockers.
If you do intend on welding tubing in place of the rockers, I’d recommend leaving as much of the inner side of the OEM rocker in place to give you a second angle and anchor point to weld the tubing to for strength and squa
my rockers are beat up so bad they are not repairable without replacing them i am looking for a solution and though this might be a good one not to ugly and a little stronger than originalThe 4x4 always seemed way overkill. 2x4x1/8” would be plenty unless you plan on pivoting your rig on rocks against the rockers, then you might want to step up to 1/4”. The heavier the material the more weight it is pulling against the lower door jams and spotwelds and floorpans. One of the reasons I just capped my rockers short with 14ga sheetmetal and will be running frame mounted rockers.
If you do intend on welding tubing in place of the rockers, I’d recommend leaving as much of the inner side of the OEM rocker in place to give you a second angle and anchor point to weld the tubing to for strength and squareness.
Says the one that ummm, mmmmm, twisted there driveshaft in halfThe 4x4 always seemed way overkill. 2x4x1/8” would be plenty unless you plan on pivoting your rig on rocks against the rockers, then you might want to step up to 1/4”. The heavier the material the more weight it is pulling against the lower door jams and spotwelds and floorpans. One of the reasons I just capped my rockers short with 14ga sheetmetal and will be running frame mounted rockers.
