What have you done to your Land Cruiser this week? (43 Viewers)
If I might ask what roof rack are you running?
Home made. 1” tube and some flat stock…. then old cedar fence pickets planed and sealed for the slats.
Removed condenser from NOS 19100-61010 Non USA small cap distributor and set points to .018. Preparing to install 89620-60010 1975-1977 igniter. Removing the existing small cap distributor and CD Porter electronic ignition. Returning to stock set up.
Also preparing to install NOS 04317-60020 flywheel cover gaskets.
Just wrapped up an entire overhaul of the steering system. New 555 tie rods, new tie rod and relay rod, rebuilt center arm (with new center arm since the old one was bent at the drag link connection), new drag link and rag joint. Set the toe in, 1/16”. Drives great only an inch of play in the wheel now, tight steering and tracks straight. Thanks Cruisers Outfitters for the quick shipping of multiple items! @cruiseroutfit
Thank you!!! :cool:
Holy drivability! Added a booster from CityRacer (with firewall bracket), 80 series non ABS master cylinder and 4 degree axle shims from CCOT.
Not kidding, it's night and day. I'm now enjoy driving it as much as I do looking at it.
Next up: A pair of amber Baja Squads.
