Hello, long time listener, first time caller.
I had the E cable(drivers side negative) come off due to a poor crimp job and then after that I had no power to anything except some interior accessories and my radio won't turn off.
I replaced the fusible links thinking it was them and I did not have a multi meter handy. I've also checked/replaced all the fuses.
I followed the steps in the FSM to check the Voltage converter relay and I have no continuity terminals 1- and E but the other terminals are good and so is the starter relay.
Basically all I want to know is if it 100% is a bad voltage converter relay, or if its something else before I go ahead and order a new relay. I was also wondering if there was any temporary fix to make it work for a few days while waiting for the new relay
picture of the truck in its current situation and the cable that started this mess for attention
