Nz Nath
Wind that fuel screw up and mash it! You will probably find you will run out of fuel/cooling capacity. I have the fuel screw in mine all the way in, fitted a 1HDFTE fan and hub, it still gets warm on long pulls.
Is that auber guage showing egt in Fahrenheit? If so definitely need to up the fuel. I run an intercooler, but I'm pretty sure my egt was really low and safe with the fuel maxed
Yeah I just had to make sure all was good to go before upping everything.
Did you do the guide wheel and boost compensator?
How much was the boost?
Just over 20psi I think. I later found out I had a boost leak from installing my inlet manifold gasket upside down, which would have been making the turbo work harder.How much was the boost?
