Any help on how to separate the Disc Rotor from the Axle Hub on a '78 FJ40? I took the bolts off the back of the Rotor (that I assume hold it to the Hub) but I can't figure out how to separate it from the Hub. Appreciate the direction!
Lug studs only need to be pushed out on 60 hubs. 40 hubs just need to be forced due to rusting.
I can verify the 1976 models had pressed in lug studs. I think the 1975 and 1977 did, too.
