Let's talk throttle bodies. The 2002 Yukon Denali XL that I started with as my base vehicle came as a Drive By Wire setup. I was originally going to retain that, I kept the pedal and control module off of the Yukon and was planning on running it that way. Then I started thinking about Cruise Control. Not a necessity for me, but I think it would be pretty sweet. I haven't worked out all the details on the cruise control yet, but another factor that led me to switch to DBC is less work on the pedal fab, and retaining the Toyota throttle cable, which for me is a rewarding dorky kind of thing when I can nearly perfectly clip the Toyota part right into the GM part. Like mixing up MegaBlox and Legos as a kid. I digress.
My dad actually had a DBC motor out of a 2002 suburban he is dropping in his 76 C10, but he wants to go DBW. It worked out perfectly that we just swapped throttle bodies and I gave him the DBW pedal and box. Dad's LS collection for the win .
In converting to DBC, you will need to make the following mods to your DBW harness and make sure you have the following DBC parts:
1) Need DBC Throttle Body
2) Need GM TPS sensor connector (I ordered a pigtail off Amazon and then ordered the Metri-Pack 150 terminals and 16-18 ga weather seals to repin it for a seamless harness) ICT Billet LS TPS Wire Pigtail -Throttle Position Sensor Connector - LS1 LSX Plug WPTPS30
3) Need GM IAC sensor connector (I ordered a pigtail off Amazon and then ordered the Metri-Pack 150 terminals and 16-18 ga weather seals to repin it for a seamless harness) ICT Billet LS IAC Wire Pigtail - Idle Air Control Valve Connector Compatible with LS1 LSX Plug WPIAC30
4) Misc wire- I have the Red/ Blue ECU with the right serial number to do this. You cannot do this with every ECU. Check out the LT1Swap.com website for all the dirty details of which ECUs are compatible, what terminals in your ECU to pin the wires to, wire colors, etc.
5) ECU needs to be re-programmed to recognize DBC functionality (LT1Swap.com also)
I ran these options through my head when planning my swap. I bought a DBC throttle body, but I ended up keeping the DBW as making the cruise control work was a requirement, and installing the pedal and control unit and harness isn't that much work. The cruise control computer on the FJ requires inputs from the original ECU to work, which it won't have. The GM ECU controls cruise control, you just need to provide it switch inputs. I'm working on a 92, so the CC switch works perfect. The original button configuration grounded 12v signals from the CC computer for the inputs. The GM ECU requires a 12v signal to the ECU, not grounds, which is provided by the ECU. So you just wire the CC signal output from the ECU to what used to be the ground side of the switch and send output on the other end to the ECU. The only problem for you is the switch changed in 93 from regular buttons that are just on/off to buttons that run through resistors. So instead of each button having an output, you have one output for all of the buttons, with varying voltage based on which button/resistor you pushed. If you get a 92 switch it will make things work perfectly.
