- Thread starter
- #81
Making sure everything fits
Don’t need a blow off valve, the BW EFR turbos have a recirculating valve built into the cover.Are you looking to fit an intercooler? A lot of the Aussie turbo guys have gone FMIC.
If you’re going to use the BOV have you worked out the plumbing? I suppose depends on answer to the above
Thanks Ryan! Your build was a big part of a lot of the decisions I’ve made so far. The plan for the actuator is to run a low boost spring and use the boost control solenoid on the turbo run off ta spare output on the haltech 2500. Lots of possibilities doing it that way ie boost by gear, etc.Looks good! It’s been many years since I did my turbo setup but I used that same turbo. If memory serves me right if you want more than 10-12lbs of boost you need to swap the wastegate actuator canister. I see that setup already has an aftermarket Turbosmart but I have no idea how it’s setup.
**with some further reading it appears that the turbosmart actuator will allow for pretty easy spring changes from 3-26psi. That’s nicer than the stock setup, where they have 3 different actuators for low/medium/high boost.**
Nice, that should work well. With the stock wastegate canister from Borg Warner even using the Haltech for boost control I still couldn't get higher boost without changing out the actuator. But at least with the Turbo Smart all you will have to do is swap springs!Thanks Ryan! Your build was a big part of a lot of the decisions I’ve made so far. The plan for the actuator is to run a low boost spring and use the boost control solenoid on the turbo run off ta spare output on the haltech 2500. Lots of possibilities doing it that way ie boost by gear, etc.
Yep you got it right. I’m taking map from what used to be the useless “gas filter” that broke off a long time ago.I’ve looked, and looked again…… I can’t see the MAF anywhere in the IC piping so I guess you’re going MAP and controlling it through the Haltech?
If so, where are you fitting the pressure sensor?
And what about intake temps?
Great work, keep on keeping on
Looking great. Who is going to do the tuning?
Nice! Looking forward to see how it does.Thanks, got a guy here in atl who specializes in haltech, and does a lot of Supras. Also has his own 97 land cruiser as well so he’s excited to take this on. Just have to get an appointment with him which is proving to be difficult.
