Gentlemens. So it seems that the plug screw on the back of my power steering pump on my '97 backed out and went out on its own adventure. Here's a thread with a picture of the hole I'm talking about, for reference.
Power steering pump
It happened about 40 miles from home, and I had no choice to but just drive home. The pump made no noises, and when I got home, it was still leaking fluid. I refilled the reservoir, but it poured out the hole exactly as you see in that other thread. I was able to push a small diameter 3" long screw driver all the way in, but on my '95, the screw driver only went in an inch or so.
Does anyone know the thread pitch and diameter of the hole? It's a bitch to get to without pulling the pump or battery or oil filter, and if someone has a pump laying around, it'd be much easier for you to pull the plug screw and measure it. Alternately, has anyone put the plug back in only to find that the pump was toast? I'd rather throw a plug in it and fill the system than just go replace the pump if this one is still good.
Thanks, guys!
Power steering pump
Thanks, guys!
